Header leak
Clone TIE Pilot
3,618
2,229
Galaxy far far away
As long as it doesn't require retorquing. There are a lot of brackets in the way of the header bolts. Some of the header bolts even have attached studs for mounting brackets.
Clone TIE Pilot
3,618
2,229
Galaxy far far away
Looks like for a replacement gasket I will need a flat one (without raised sealing rings) with oval ports. Also does anyone know the size of stock 416/601 head exhaust ports?
Rt Jam
504
458
Ontario Canada
The best gasket will not seal a bend flange. 2 ports with only 2 bolts is not an easy thing to seal. Check that flange for straightness.
