GT_80 said:My limited experience with G bodies, long tubes require some finess to get it. I have used Flow techs in a 1980 Malibu wagon I had years ago, and it took a while to get them in. I scratched the hell out of the paint on the drivers side because i was frustrated, but they were OK fit and finish, they just don't last too long if your car sits a lot or unless you paint them once a year.
I only had that car a year, so it wasn't a big deal to me.
The questions I want answered, is how do people account for the drivers side header pointing straight at the trans crossmember? do you have a funky bent pipe or simply flatten the crossmember (which is really hack!)?
The cutlass I am getting has manifolds with header back 3" exhaust, and someone along the line has 5lb sledge hammered the cross member for clearance, but I would like to fix it correctly and put headers on it.
You see, i didnt expect a problem as such to arise when installing long tubes and needing an aftermarket crossmember for a "clean" install. I dont have a problem with flattening a spot or two to make clearance. Just wondering how much of a trouble is this car going to be right off the start haha
Is an aftermarket crossmember the only solution?
Starting to have second thoughts about getting it and spending the money on my LT1 F body 🙁
