headers over exhaust help
malibu-man400
11
Hey guys,
I was just wondering, what is the difference or what make headers better than the regular stock exhaust. Is there a preference to which a car should have?,if so, why? Does headers make the car sound a little bit meaner or is there ways to mod that?
Phoenyx
2,392
7
Alberta, Canada
Headers a better designed at flowing than stock manifolds. So they make the engine run more efficient, which will make more power and give better fuel economy. I think on a stock build the difference would be very small, if anything.
As for what a car should have, it depends on a lot. Lot's of people have continuous problems with gasket leaks. If they are long tubes, lowering can cause problems. I would say (and I'm not an expert lol) unless you have 350-400+ HP then manifolds would be just fine.
And for the sound. I have heard a few cars that had headers put on, and kept the same exhaust system. And yes, it does sound different (better) than the manifolds.
rustyroger
502
6
Margate, UK>
Manifolds are much cheaper to make than headers, that's why most cars leave the factory that way, good headers are often a cheap and easy way to improve a cars performance - both power & economy. Certainly that was the case when I first took an interest in engine tuning on the little 4 pot engines in British cars of the '70s. Any tuning guide recommended upgrading the exhaust as a first step, some engines responded better than others, minis would typically see an increase of 10 bhp from a manifold change -from 38 to 48 bhp - enough to power a th400!
Most people who fit headers like their car to be a bit louder, since the rest of the exhaust system often needs to be modified or replaced it's a good time to fit one that gives the desired sound.
I prefer my car to be as near silent as I can get it, headers can work well with this, a good exhaust fabricator can make a quiet system with little or no performance restrictions. The downside is it will cost more, mufflers are more expensive than straight pipes, particularly good ones.
GhettoRacingKid
775
6
like the above said.... on a stock or mild performance build it doesnt really matter.
but you still need some back pressure and the primary tube size has a long to do with it. you dont need a crazy big primary unless you are pushing that kinda cfm out the exhaust.
I know flowtechs sound good and are cheap and arent bad to install. some headers create interfence with other parts such as linkage and or the oil filter etc...
I had flow tech years ago. they sounded good and were like $120 at the time.
now i have hooker headers with a larger primary but im pushing more power so its needed. and they sound good i guess. havent really listened to them since i got dumps on the car.
ohh i like 2 1/2 exhaust with 2 chamber 40 series flow masters but thats just me.
