I'm running an Aftermarket T56 with my SBC. It started as a T5/SBC with the F-body hyd bell and master/slave. I am also running an F-body Hedman 1 5/8" shorty header for dual cats. Melted the plastic line going to the slave. Due to other issues, bought a new slave/master setup and re-routed line away from header. I personally never liked the hyd actuation plus my clutch was still slipping like it wasn't completely releasing the clutch. When I swapped the T5 for the Aftermarket T56, I went with the Lakewood bell for an 82-83 Camaro (15015) with the mechanical linkage and used stock A/G body clutch linkage. I, myself, like this setup much better. Re-used the same Camaro headers.
I'd like to find some 1 3/4" full length headers that will fit a manual transmission (that doesn't cost $500+ !!!). I don't see much point going from 1 5/8" shorty to 1 5/8" long tubes.
The hyd slave *can*, in some applications, pose fitment problems in some brands of headers. Best bet would be to run a hyd throw out bearing and run the line around the header. Then you would have the ability to run any header you wanted.
