Heater/AC problems
KapPartier
47
Atlanta, GA
bill said:
Very carefully!....the covers snap in, so it takes gentle help with a butter knife to get the covers off. Id start with the radio, then work up to the ac/heater control. I would suspect the blower switch is shot...but before you go this route, check the relay under the hood for the blower...make sure its not the problem before you take apart the dash.
Let me ask.. I see how it looks. But if you take a wire, and run it from the power part of the blower to the positive post of the battery, the blower suppose to turn on. Well it doesnt, so what does that sound like?
KapPartier
47
Atlanta, GA
Hey as I was checking my relay, I was in the process of pulling the wires from the relay. Then I seen a spark on the blower. So I played with the wires, and the spark came from the ground wire. I played with the ground wire a little and the blower temporarily came on. So I just screwed the ground into a different screw and it came on. Now I have heat and some what ac... Lol thanks everybody for the help.! :mrgreen:
bill
2,332
11
38
southside va/lake gaston
:banana:
