"Thank you for all your Input...where I live no one has knowledge on old cars. Question I have if you have time when I order motor mounts and the transmission mounting kit for this SBC 350 motor that I'm putting in my 1981 cutlass supreme since it's a Chevy motor what year and make do I order the parts under? Some one told me if I go the Autozone ask for parts on 1984 Monte Carlo is that true also when I went to ordered motor mounts under that make and year I told them it was a 350 and they said motor for that year was 5.o and they asked me if it was 3.8 or 5.7. Thank you for your help."
Olds cars in that vintage came with 3.8L Buick motor, 260/4.1L or 307/5.0L Olds motor. Others will have to verify Buick/Olds/Pontiac info. Sure, tell Autozone you have a 1984 Monte Carlo. The engine bays were about he same for most G-bodies. Autozone will look up your car and tell you what the factory options were. 3.8L V6, 4.3L V6, 5.0L V8 were pretty much all that was offered in Chevy motors. The 5.7L/350 was only offered up to 1981, I think. So, when you need to order parts, tell them it's a 5.0L/305. The 305/350 shared crank, rods, timing cover valve covers, oil pan, water pump, distributor, intake manifold. Only difference was cylinder bore size and pistons, although the dipstick moved from driver's side to passenger side around 1982 (?).
First, let's figure out what you have. Try to find the casting number on the block. Look on the back behind the distributor. Look for a 7- or 8-digit number cast into the web where the trans bolts on. Could be on the driver's or passenger's side. Here are a couple photos to help. With luck, you don't have to scrape much junk off to find a number. Search Google. This will hopefully tell you more about what you have.
If you can see the back of the engine, check out the crank. If it's small, round, and has an aluminum adapter around it, it's a late-model 1987+ one-piece rear main seal block. These leak less often. If the crank is not round, and has iron all around it, it is the old-style 2-piece main seal block, 1986 and earlier. The oil pans are different between these two types, but the timing cover is interchangeable. By the way, in the photo with the finned valve covers, notice that I have Vortec heads on a 1960's truck block - you can tell by the two vertical bolt heads at the corner of the manifold. They bolt on just the same as old-school heads.
The serpentine belt system you have looks like a Camaro/Firebird type from 1987-1991. Hope you have all the pullies. Make sure the water pump that is on there is for 'reverse rotation', or it will not pump the water correctly and you'll have over heating problems. No way to tell from the outside. If you have doubts, replace it wit the correct 'reverse' type - they're cheap enough. Same problem with the fan. The picture of the fan shows the right angle blades. I got mine off a 1990
Caprice 305. Camaros used an electric fan. Last, you'll likely need a fan shroud. Good luck in the boneyards. Any G-body with a chevy V8 will be what you need. The Olds one may work, but only from the V8s. I'm not sure.
Small-block Chevy motor mounts are pretty much universal 1975-2000+ and TH350 trans mounts are either round or rectangular. I like the rectangular ones. Check you crossmember - some V6 cars had an offset trans mount to dampen vibrations.
Keep the questions coming. I don't sign on every day, so please be patient.
Check out Rockauto.com. They have good prices, but the computer search tool is the absolute best in the business. You can compare part numbers between different years of cars and learn stuff for yourself.
You may have to pull and install the motor several times while you figure things out. The headers are often easier to install just before the motor is dropped into the mounts, but may be a PITA to have bolted on while guiding the engine/trans under the firewall/tunnel.
Hang in there. This takes time to figure out.
