Help bleeding brakes
trapnewton
6
34
So I changed my brake booster with the master cylinder all together and now I'm In The process of bleeding the brakes ,I started on the rear passenger side , but I got stuck there lol
I put a clear hose on the little valve thing with a bottle at the end , but when I opened the valve , nothing came out ,I even removed the valve completely and still nothing came out even after pumping the brakes .
Can somebody tell me what I'm doing wrong ?
85 elcamino btw
If you didn't bench bleed it you can do it with it on the car. If you bought a new master the bench bleeding kit should have come with it. If you used your master and don't have the kit you can get one at the parts store or make one if you have the tubes and fittings
Very interesting. Thanks for post the video pontiacgp! I removed mine for the front end clean up. Now at least one head ache will be avoided!
