custom442 said:If it's set correctly to begin with, don't see how you could set the dist 180 degrees off... just line up the 1st spark plug with the rotor at TDC.
There's many more reasons than the same thing being said over and over that could cause it to backfire
dan2286 said:custom442 said:If it's set correctly to begin with, don't see how you could set the dist 180 degrees off... just line up the 1st spark plug with the rotor at TDC.
You can get tdc on the compression stroke or exhaust stroke. 50/50 chance. Not everyone thinks to check which one it is on. Yes I have done it also :lol:
custom442 said:dan2286 said:custom442 said:If it's set correctly to begin with, don't see how you could set the dist 180 degrees off... just line up the 1st spark plug with the rotor at TDC.
Right, which is why you turn it by hand and use a paper clip to see where the piston is through the plug hole, I thought this was common practice
Maybe I'm just green with that kinda stuff, but it seems simple enough if you're turning the engine and it's compressing and it's at TDC then that's where you need to be
jrm81bu said:That paper clip still ain't gonna tell you if it is on the compression stroke or the exhaust stroke.
