HELP!!! Fans are not blowing !
Lorenzo
450
6
30
Milton Ontario
Ok so today I went to go turn on my fans to bi level under ac, before all it did was take some cool air from outside. I noticed nothing was blowing I tried my heat and still nothing ! All the settins and from hot to cold and nothing ! Please help!!
:bump:
bad blower motor?
How can I check if it's bad ? and where is it located ?
Mine is located in the engine compartment on the passenger side, near the firewall. Not sure about montes. Mine had about 6 screws or so holding it in my ac box. Check to see if it has 12v to it when on, if so then bad motor. If no 12v then something else. Maybe fuse or resistor.
Like when i switch it to bi level or heat i hear like all the vents are opening up and when i close them too they make like woosh sound. Does this mean for sure my blower motor is bad? I cleaned all the connectors for the resistor and took it out and it didnt look to be burnt or damaged.
check blower relay its bolted on the front of the blower box beside the ac dryer canister
How would i check tosee if that is broken?
Ok so i took the blower motor out and wire it straight to the battery to see if it would spin and nothing happened, so theres the problem right there i guess.
problem solved
