Help, Front Lights don't WORK
o ARC ATHEISTxX
146
Los Angeles
I recently removed my whole front clip to pull the engine, and I just put it back and my front lights are acting funky.
This is the setup I have n the front, when i turn the head light on non of the yellow lights turn on and my left arrow signal stays on.
But when i put the hazards or turn signal it works okay on the side that is activated. Any input is appreciated
monte olrac said:
check your ground wires to each light, they are known for going bad
I double checked the connections, do i have to replace the whole wire?
Check each wire for damage and corrosion. I had a similiar issue so I went through and redid all the splice and connectors that the previous owner did such a great job on. More than likely its something thats small and an easy fix its just chasing it down is the hard part. I have been chasing a taillight/brakelight issue since mid November :blam:
