Situation:
Using stock 84 GP gas tank and sending unit -> to electric fuel pump (50 psi) mounted lower than the gas tank -> to fuel pressure sending unit at the fuel rails -> to 60 lb. fuel injectors -> to Elelbrock Proflow EFI system -> to 555 BBC crate motor.
Problem:
Fuel starvation at WOT, and fuel starvation for no apparent reason, uphill/downhill/straight/etc... Fuel pressure just DROPS to 20psi and stays there, for NO reason. The car will idle at that fuel pressure, but will not move (will stall out). While driving, I've had to stop at the side of the road and wait. Took an hour long wait sometimes for it to come back to 50psi, other times, it only took 5 minutes.
I think since the fuel has to go UP through the sending unit -- this is what's causing fuel starvation. But even with a FULL gas tank? WTF?
I don't have a lot of money left and it's currently sitting in the storage unit. I don't want to waste any more time/money if I don't have to. It's a new tank, and my SECOND new fuel pump ($500) since my car was sabotaged with bleach and ****ed those systems up).
What is the "correct" solution for me?
Has anyone converted their setup to fuel injection, successfully? If so any ideas are appreciated!
Problem:
- sump the tank?
- baffle the tank?
- Edelbrock said to mount the fuel pump inside the tank... but how the hell do I do this?
- scrap my tank and pump for a 85 Montecarlo TBI fuel tank, sending unit, & in-tank fuel pump? Does the Monte in-tank fuel pump support 50psi of fuel pressure?
