hey everyone, looking for experts to help me read my spark plugs. I've been doing some ignition tuning and the performance has generally improved. I've been experimenting with more ignition advance, and idle mixture on my Holley 750 carb. I will be rebuilding the carb and experimenting with jetting then.
These plugs are Champion RC14YC. http://www.championsparkplugs.com/resul ... c&x=43&y=6
I am running a large 0.053" gap for more spark exposure. I have a upgrade Accel dizzy, coil, and 8mm wires.
The motor has L98 58cc ported heads, with larger valves (2.00, 1.55), 10:1 pistons, and I am running 36 deg of total advance, all in at 3700rpm. I’ve tried 34 & 35 deg, but I will need to see the benefits of less advance at the strip at top end.
The Holley 750 has 73/83 jets. I am using 91 octane fuel. And a thing worth noting is, there seems to be some blow-by and I suspect the rings are getting worn.
I'll start with the right bank (1, 3, 5, and 7)
#1
#3
#5
#7
The left bank (2, 4, 6, and 8)
#2
#4
#6
#8
#2 appears wet to me, #1 is discoloured, and most others are white on strap. All plugs came out black on base.
#1
#3
#5
#7
#2
#4
#6
#8
