help plz! problem w/ headlights/brights
84mc
9
This all started after opening my column to look into the shift lever spring. After I put it back together my brights lever would not hardly click. Then it became where it would click and the headlights would go out then click it again and the brights would illuminate. Then it got to the point where I would turn on the headlights and there would be no lights until I clicked the bright lever then the headlights would illuminate. Now the brights stay on and will not click off. I also have one headlamp pigtail that is not powered up it is a low beam as well. Grounds are good and I did t not touch anything in the column beyond the round access plate that's held on with a round clip. Any suggestions before I start throwing parts at it?
Ended up being a bad dimmer switch on the top lower half of the column
