ok so i have comp magnum roller rockers on my engine. got it in the car and all wired up. engine was test fired on the stand after all lash was removed from the rocker arms. ran engine in car, however it was running a bit rough, (new carb, unadjusted valves, and no fine tuning of the timing). so i pull the valve covers to adjust the valves like i normally do, but soon as i put the socket on the nut of #1 exhaust the engine dies out(i did not adjust a thing at this point). so with the engine off i look at it and the socket wont fit in the rockers to adjust the valve unless its at a certain point, kinda jams in there unless it is just right. so i get an old 5/8 socket and grind it down and still the same thing. so i try to adjust everything statically. tdc #1 firing position, adjust the valves which are able to be adjusted the rotate to #6 firing position and adjust others. get to zero lash and then 1 full turn , put the valve covers back on and and try to fire and sounds like no compression so i repeat the procedure except only tighten 1/2 turn after zero lash and then the engine trys to fire with a backfire out of carb. so i go to tdc and check the dist, and rotor points to #1 cyl like it is supposed to. so i tweak the timing a bit to see if she will fire. no such luck only backfires out of carb. sooooooooooooooooooo what should i do. i would like to get the car running for my birthday on thursday. i have been working on this thing for a year and am looking forward to completion. so how do i go about adjusting these valves and getting thispig running. all engine specs are in my sig by the way. thanks in advance guys.
