valve adjust
guys, i dont know if your doing this but i've seen a lot of machanic's trying to adjust valves and doing it wrong!! what they would do is back the rocker nut until it made noise and then adjust until the noise stoped. which is the right thing to do, then they would try to add the 1/2 or1 full turn while the engine was running which is the wrong thing to do!!!! the proper way is adjust all eight on that side and shut the engine off and then make the final adjustment and put the cover back on and go to the orther side.. i set mine at 1/8 turn and i works for me i hope this helps 😀
