Without having read the replies, I will give you some advice as i have been in your position many times.
My position will not necessarily be the same as yours as i most of the times havent had a stationary place to store it while restoring them. Alas.
My builds goes something like this:
If the car cant move by itself, this is the first thing i fix. Get the engine running abd the trans shifting. I dont put much effort into tuning, if any, as getting it running is required so i can move it around as the work progress.
With the car able to move by itself, i take it apart and fix the exterior rust
Then i paint it.
Put it back together.
And, this one varies a little. But i swap the engine and trans to prefered combination.
Make a custom exhaust
Replace all bushings, especially the body bushings. Springs shocks etc.
Fix the brakes and steering.
Tune the car and get an inspection so it's allowed to drive on the road.
Work on the interior if needed.
And by the time i've done this, i've thought about selling it a few times and build something cooler. And thought about 1000 projects to do to it also.
Ymmv
Then i paint it.
Ymmv
