83 5.0l
I just had my intake manifold gaskets changed, And appearantly the guy did a bad job on it. So, Instead of taking it back to him, And fighting with him to make it right, I figured id step up to the plate, And do it myself.
The leak is on the Back side of the motor, by where the heads, intake manifold, and block all come together on the Pass side. What im HOPING happened, Is he used to stock rubber gaskets in the back [Which i heard is a bad idea], And didnt use any sealant on the corner's.
My problem, Is pulling the Distributor. Do i mark it at the base, Where it meets the intake manifold, AND at the top, Where the rotor's pointing? If i do this, theres no way i can put it back in wrong, correct?
Also, what is the torque spec's on these manifolds? I was reading on the edelbrock sight, and it was saying 25ftlbs for thier manifold's, Does this seem right? Can i use thier tighten pattern as well?
Im hoping it isnt the Head gasket, But i checked the Oil, And it isnt bubbly / milky, Dont smell sweet, Isnt over, or anything like that. Most the water thats leaking, end's up on my firewall by my heater core hoses.
Any help would be appreciate.
