HELP WITH IROC RIMS
MYOBYDAVE
31
6
tri state area
I HAVE A 1987 CUTLAS SALON
AND LOOKING AT THESE NICE IROC RIMS
JUST WONDERING IF THESE NEED SPACERS OR WILL THEY JUST FIT ON ?
WHAT ABOUT RUBBING FRONT AND BACK?
FRONTS LOCK TO LOCK GOOD OR NOT ?
THANKS
It depends if they are all front iroc rims or are they two fronts and two rear iroc rims?If they are all front rims they will fit and won't require spacers but if they are rear iroc rims they will require spacers.
OE or aftermarket?
16,17,18,20,22,or 26"
Kinda vague question without specifics.
If they're OE, it'll take 4 fronts
If aftermarket, will depend on size
455cutlass said:
It depends if they are all front OE iroc rims or are they two OE fronts and two rear OE iroc rims? If they are all front OE rims they will fit and won't require spacers but if they are rear OE iroc rims they will require spacers.
Ribbedroof said:
OE or aftermarket?
16", 17", 18", 20", 22", 24", or 26"
Yeah, what they said
I have IROC wheels on my regal and you will need a spacer on the rear. I'm running a 1" spacer out back. No spacer needed for the front. I would highly recommend a steering box off a 3rd gen fbody that came with 16" wheels. The factory steering stops on our cars are useless when running16" wheels. The z box as it is sometimes referred to will keep the tires from rubbing the sway bar and lower arm when at full lock. The downside is your turning radius will increase.
