OK so I plan on redoing the dash, putting in aftermarket gauges and such.
Tell me if this is possible...
I will have the gauges back lit with blue led's. I want to make some sort of circuit so that when the oil pressure goes too low or when the temp goes too high, such as warning me that a belt has snapped and the water pump is not turning. When those 2 things happen I want to have RED led's behind the gauges too and they will turn on and the blue will turn off.
This way instead of having only a little dummy light, I have it all in my face and can't miss it. I don't need it for the voltage cause if the power goes down, the lights would dim anyway.
