khan0165 said:one more thing...
I highly recommend the new style of oil coolers, that have passages build into the fins.
this is the old style
they work, but I find the exposed fins are easy to damage and bend up...
you can find alot of installation info thru google...
thanks...so i dont want to use the stock steel hose so which kind of hose do you prefer i use ?khan0165 said:that looks like it has fittings for hoses... So I say go down to your local auto store and pick up some 3/8" fuel line.
and that looks like the 3core rad I've got in my GP!
score!
nice find man
can't say I've ever seen anyone paint a cooler/rad...442Jayp said:thanks...so i dont want to use the stock steel hose so which kind of hose do you prefer i use ?khan0165 said:that looks like it has fittings for hoses... So I say go down to your local auto store and pick up some 3/8" fuel line.
score!
nice find man
and would it be a bad idea to spray paint the radiator and trans cooler...kinda want it red
you should need to mount it...442Jayp said:ok and what should i use to mount the hose...dt need it dangling and getting burnt
