dave6184 said:Ok I have an 85 Monte Carlo SS with the factory 7.5" rear non posi. I want to add an auburn posi unit but Im not sure what series carrier I have or how many splines the axles have.
MonteMan1987 said:...if its a true SS it should be a 3:73 posi...
85_SS said:MonteMan1987 said:...if its a true SS it should be a 3:73 posi...
This is incorrect. Posi was an option, and an uncommon one at that. Only about 1/3 of SS's actually had it from the factory. I have owned 3, none of which were posi cars. Most cars were dealer ordered, so they didn't add options that weren't flashy. Also note that 83/84 SS's came with a 3.42 rear (and TH350c trans).
you're applying logic to GM, it doesn't work. hell, they made the GN without a posi!!!i thought that was one of the perks of it being an ss was the HO motor and posi rear.
megaladon6 said:you're applying logic to GM, it doesn't work. hell, they made the GN without a posi!!!i thought that was one of the perks of it being an ss was the HO motor and posi rear.
MonteMan1987 said:...one of the perks of it being an ss was the HO motor and posi rear. and being a 1985 it should of been a 3.73 with the overdrive transmission.
