no it is not an o/d just a 3 speed automatic has something about metric on the bottom of the transmission thats all i really know about it though
dan2286 said:88hurstolds said:You will not be able to use the idiot lights, they are controlled by the computer. Plus the idiot lights do nothing for you to begin with. Also you will need to find a pre CCC HEI distributor from 74-79 I believe or the stock one from the 403.
If you are running a lock-up converter trans you will need to get a lockup kit from Summit or Jegs for the computer will not be able to lockup the trans anymore.
The computer does not control the idiot lights. It runs off of a completely different wiring harness. The only light the computer controls is the check engine light.
Or you can do what I did and follow each wire from the computer back towards the fuse block and under the dash and remove them at the source, this will include the cruise, a few grounds and the check engine light. You will also wind up with two extra power wires that you can tuck away for future use with lighting or any creature comforts. I had the dash removed when I did this...82cutty said:You should remove the check engine bulb or it will be on for ever....
