I have a 1986 cutlass which I just dropped in a 1971 350/350 combo in along the crappy 2:14 rear gears.My question is when I'm driving reasonable highway speeds(60-70) my rallye pac tach reads at like 3000 rpm's, whatz up with that. Someone please let me know if this is normal or not as I'm not trying to kill the motor!
3000 rpm's seems alittle high for that gear ratio. Are you sure they're not numerically higher? Are you running small diameter wheels and tires?
Is the tach reading accurately?
I have 14" rallye's and as far my gear goes my rpo codes says I have a 2:14 gear ratio and I doubt that it's been changed out and I also believe that my tachometer is reading correctly. The car originally came with a vin y 307. I'll be happy to give you guy's any more info you need for a diagnosis.
