Cold weather for me means a sortie into the parts stash to locate parts for the next stages of my Monte project. When I bought my project it came with a motor that was not stock to the era. By this I mean that when I pulled it, I found that it had the one piece rear seal modification along with the matching crank and possessed center bolt rocker covers meaning that the heads were also different from 85 and older. What I did not particularly notice at the time was that the bolt pattern for the starter had changed too. Instead of a long and short bolt combination and a staggered pattern, what I had was two long bolts and an in line pattern. A quick pass through my parts exchange manual did tell me that the pattern difference was an indicator of the tooth count on the ring gear. Staggered meant that the ring gear had 168 teeth, a count that I had already verified through other means and which was correct for an 85 and back small block. The in line pattern, by contrast, supposedly indicates a ring gear with 153 teeth. So yet another change from generation to generation. Not a problem, more a nuisance, as it meant I had to pull a correct starter from the shelf. However, when I pulled that unit and took a peek at it, I noticed that, tucked under the solenoid cap, there was a hole in the starter body just behind the grommet that the copper tabs from the field windings come through, about 1/2 inch in dia, seemingly drilled, that was open to the world. Which immediately raised the question of pedigree since starters and their associated part numbers are about as many and as prolific as socks in a drawer. For the 85 Monte alone there are at least a dozen different numbers and two different production runs.
So my question to the forum is this: What is the purpose or reason for this hole? As mentioned it does not appear to be some kind of damage, too regular in shape. Should there be some kind of plug or cap inserted into it? This starter is not a new or reman unit, to borrow a phrase it is "barn-fresh", by which I mean it has been sitting on the shelf for a while. Probably got put there when I built the shop; a survivor of a salvage job or snagged from the yard when they were thinning out the herd. Not rusty or damaged, teeth on the Bendix are in good shape. Have not motored it to see if it will spin. That is the next thing on the list. The parts identifier doesn't make mention of this anomaly. Any ideas or suggestions?
