pillability said:thanks alot the transmission in there is an old th200. i was thinking the best way to go would be to go find a th350 and do a stock rebuild with a shift kit like mpac suggested.
It would be alot easier and cheaper to go that route. Also if you do go with aluminum heads you will really shoot up big time over 300 horsepower. BUT there is a couple things you need to watch for with aluminum heads. The nice thing about aluminum heads is you can get a way with more compression on pump gas then you could with cast iron, also you get a nice weight savings. Just an idea of the weight. My RHS aluminum race heads are 19 pounds a piece. But with aluminum heads they are alot easier to warp if your not careful. Also with some aluminum heads you need to double check the toquring spec when bolting them on since aluminum is softer. Over all I think if you looked on craigslist and found a nice set of vortecs for about 250 to 300 then went through them you'd probably have 500 dollars tops in them and be well over your goal. Or if you want to go with aftermarket with a good brand and a cheap price.
http://www.jegs.com/i/Patriot-Performan ... Id=1192214
