How Can You Get ONE Key For ALL The Locks On Your 79, or 83-86 A/G-body Car?
69hurstolds
I know nothing!
8,982
19,851
If you're like most people, one of the nicer thing you find about newer cars is that they usually only need one key and/or fob to do everything for your car or truck. Less keys, less junk swinging from the ignition, or sticking you in the leg while in your pocket.
This trick only will work on G-bodies from 1979, and 83-86 cars that used a "B" series oval key for everything but the ignition lock. It also will take a bit of work, but the possibility is there. I've seen people do a lot more work for less.
First, you have to obtain a COPO Fleet GM ignition switch, p/n 7843294. Briggs and Stratton (strattec) number 608361. This over-the-counter switch p/n is the newer style switch that uses the retainer bolt in the column (OEM factory used the 1978 style switch in 1979, although the newer screw-retained switch fits for field replacement). This is the only ignition switch I've found that uses an oval key to operate. So far, I've only found them to have "B" keys, so that's why I said those years. Of course, you can always swap over the entire car with a "B" keyway lock set for glovebox, doors, and trunk and be just fine. Other than the oval key, it's the exact same as the other ignition switches. It was used originally in some 79 through mid 80's GM vehicles. Why? God only knows. I suspect they could be fleet use where one key does it all for company vehicles and have one key for each vehicle to keep up with, but that's just a guess.
The only real PITA about it is that you'd have to get the ignition switch with the oval key, then you'd have to have all the other locks re-coded to match. Is it worth it? I dunno. I don't need to do it, but just throwing this out there in case anyone wants to go through all that just to be able to use one key for everything.
There's ANOTHER way you could do it, although it would be a bit tougher. Briggs made some universal unrestricted lock cylinders that you could use any key in and get the same result. So say, if you have a C ignition key, you could use your C square key in any other lock and make it work. Again, this means you get the ignition switch key and then match code the other unrestricted locks installed and coded like your ignition key. It's harder because the unrestricted cylinders are much harder to find nowadays.
I wouldn't expect anyone to actually go through all that crap for their locks, but just know that it's an option if you chose to want to tackle something like this and as long as you could find the 7843294 ignition switch locks. It would definitely be rather unique.
I used to have a 9C1 caprice that used only one key for everything. If one could find car being parted out might be worth a look, not sure if the door and trunk locks would be the same as a G body though.
Some time back I saw on Fleabay an export set for a A/G with the B key & contained all 5 needed locks to do the conversion. Boxed & ready for the assembly guys to instal or convert.
Here's another set I found on a quick search.
Dixie Restoration sells a kit with all the locks that use a single key
Are they GM or OEM? Or aftermarket? If aftermarket I don’t follow those much. That’s another source if you don’t mind using aftermarket stuff.
If the pictures are accurate the fleabay link is for the earlier locks 1969-1977 with the spring tab to secure the lock in the column. 78 up would have a groove cut in it to use the screw to secure the lock in the column.
Early Lock.
Late Lock.
Now that's a GM fleet kit. The 44L3 key stamping on the ignition lock corralates to a 1973, 81, or 91-00 "H" key. Thus, all the locks in that baggie are "H" key slots. Strange. Note too, it's the early ignition lock. This is the first time I've seen something other than the "B" key on one. It just depends on the year they're manufactured.
I didn't even think to look into what key in this set. Thought I was watching the other set in my list for Jr.'s car parts but wasn't there.
Early Lock.
Late Lock.
Actually '78 is the same as '69-'77. '79 was the first year with the retaining screw.
  • Informative
Still mislabeled as 78-88. The glove box handle wouldn't fit my 72 so it's got to be newer than that. I think that kit is 1978 only. I will admit i don't know much about 73-77s so it might be ok on one of those. 73-77s just don't turn me on.
