How do you know front clip is lined up with body?
Gnfanatic
22
6
Good morning everyone, replaced all my body mount bushings on my 1986 GN. I know the frame has holes to align with body and I did that but is there any holes to align front clip?? My front clip moved side to side quite a bit when replacing the bushings. I am not sure if it is a visual thing or there are alignment holes. I cannot go by door gaps because they were removed for new door hinges.
thanks!!!
Rt Jam
594
587
Ontario Canada
You will need to work backwards if you lost the door alignment.
Get the door gap set to rocker and rear quarter. Then use the radiator support bushings to set the height of the front clip. Up or down will change the door to fender gap.
I centered my radiator support bushings and my hood fit perfectly but the hood will determine if you need to move the front left or right. Maybe a diagonal measurement will set you up there.
Gnfanatic
22
6
Thanks for the reply! Do you know what the gap between door and quarter is suppose to be?
57 Handyman
339
389
I have read somewhere (can't remember for sure) that a good gap measuring tool is the thickness of a wooden paint stick.
Gnfanatic
22
6
I think that is a very small gap for gbody and GM 80-90's cars. My friend has the whole service manual , I am going to see if it states it
ELCAM
1,124
1,270
Off the top of my head it is .1-.3". Never seen one that was as tight as .1 so to me that is the best case scenario.
spongbob
129
74
IM going to say about .25 if the age and time allowd for satisfaction .the actual door metal any shims ect ect.main thing the front finder face should be 1/16 further out(away from center) then then the face of the door skin .for clearence adjustments can be annoying. Don't forget to set the latch post if the door raised with new henges and door should be level to face of quarter panel here .Sometimes a matter of good compromises
Tony1968
2,324
5,132
NW Indiana
I used paint sticks that were exactly 1/8th or .125. Worked well.
