How fit 6x9 in 85 grand prix
Antredd77
16
2
I have 85 grand prix but I'm having hard time putting my 6x9 in and trying to fit 6.5 in front doors can anyone help
565bbchevy
9,614
12,683
Michigan
They make 4 x 10 to 6 x 9 adapters but I like to cut a notch for each 6 x 9 speaker under the top of the rear deck behind the rear upper seat and mount it directly to the deck and then I open up the hole closer to the size of the 6 x 9.
For 6.5" speakers in the door if you have power windows you can mount them where the window switch is and move the switch down to the lower door panel, I did this with both my Monte and Regal.
Antredd77
16
2
You got pics of your rear speakers how you put in and my front doors are not powered window they roll down with handle
AZRegal
178
502
Mesa AZ
In the past i have mounted 6x9s in the rear armrest area in the back seat. I took the lower plastic panel out cut out a hole in the card board rear door panel that fits the 6x9. I then reinstalled the plastic panel and cardboard door panel. Mark the hole you cut in the panel onto the metal in the car. Remove panels again and use a skill saw to cut the hole in the car. The hole you cut then holds the 6x9 and that cavity feeds back to your trunk space. So it still uses the trunk as the speaker box so to speak.
They make these things to mount speakers in the area i am talking about without cutting the metal in your car. But it is not for a 6x9.
1evilregal
3,056
4,357
Greensboro, NC
got my adapters off of amazon for $14... if you have a stereo installer near you, you might be able to pick up a set locally
