pontiacgp said:
what about the volts at the in and out side of the oil pressure switch?
Running 13.4 in & 13.4 out at the switch
10+ volts at the choke ( not plugged in )
Key-on but not running 12.5 in & zero Out
9.5 volts at the choke ( not plugged in )
I pulled down a schematic from mracing
On the Choke / Heater circuit there is a single 20amp fused line wired to the switch ( brn/wht )
then to the Oil Light Indicator (also brn/wht)
^^ both of these are on the same "hot" pole of the switch when plugged in.
Then from the switched side there are 2 wires
lt blue to the choke
dk grn/wht to the Choke Light indicator
Now I am curious as to why the choke light is on, and if it's on why the oil light is not on or vice versa.
My car was orignally CCC equipped but when I removed it originally and swapped over to the non-ccc dist and carb all the idiot lights and guages were unaffected.
It must be a simple fix, just need to wrap my head around how the wiring works and why the choke light would come on in the first place
