you dont need power brakes. if you drive for a little bit without them you will not even notice they are gone.ditch the brake booster. with 7 psi and no more, you could use the stock short block. it has 8.5:1 comp. the heads flow really well in stock form. only vortex will outflow them stock. get a small cam that is ground for a turbo and you could easily build 450+ hp with motor. keep rpms under 6000 and it should live.
