update.....I have installed the oil pressure switch that Joe recommended. However, when I hook up the oil pressure warning light wire to the center terminal on the OPS, it stays on when the ignition is off and goes off when the motor is running. Any explanation as to why? The choke heats up fine as intended, but I still want the oil pressure light to work as well.
