carmangary said:I got it going today. I just poured about 6 oz into the compressor in both sides like you guys said. There was no oil in the system for some reason. It's blowing cold air now. The pressure is high (55/250) but it's working. Not sure why the pressure is high. My shop manual says it should have 3.75lbs of freon. I added 3 lbs and stopped since the pressures were high. I'll see what it does for awhile unless someone has a suggestion.
I am not positive because I haven't dealt with a/c in a while, but I think the pressure specs are supposed to be at a specific outside air temp. I believe there are charts out there to look at.
