Hey Guys, I hope someone can help me out
I own a 83 GP and I discovered my carpet was getting damp. The driver floor has been replaced, and raised. So I thought the weld job was bad and water was being scooped up when I drove in rain.
I tore the interior out and found my floors rotten. The insulation was soked in rust and mold, and luckily the carpet is still fine. However, I discovered that the floors are not the problem.
I quickly started to diagnos all the typical G-body rust/leak areas; ie the windshield, door seam, front cowl areas, etc...
The winshield and door areas are fine.
On the passenger side, the seam where the floor meets up at the firewall is rotten and water gets in when driving... no big deal
The driver side however, is a whole other issue. Through hours of water testing, I've determined the water is going in around the left cowl area; behind the fender, at the back of the inner fender, under and beside the wiper motor.
Took the car to my trusty body shop, they repaired the floors and found two holes; one along a seam between the braket that holds the wiper motor and front fender, and another somewhere under the dash.
But, the leak is still there, from the exact same place, coming in the exact same way. And I am convinced it is leaking from where I described.
My question is; how do I take the front fender and inner fender off?
I can't get a tool in the door seem because the door gets in the way. I can't get the back inner fender bolts because the wiper motor gets in the way. And I can't figure out how to seperate the inner fender underneath in the wheel wells.
I'm really stuck, and this is a major problem because I rairly have indoor storage.
Can someone help me out? Pictures would be handy
here are pictures of underneath my hood, where I have a brake proportioning valve attached to the top of the inner fender, and an external fuse box attached at the bottom front.
here is a picture of the inside showing where the water comes out
and here is a picture of a GBODYFORUM member's car, that shows where I think the rain water is going in
