Yes, I know that it is suppose to stick out but it would not go in as far as it should have. The axle would not go in far enough to be able to insert the C Clip.So.....the repair bearing you got is designed to stick out, it moves the bearing and seal out further closer to the axle flange to move the seal and bearing to a non worn portion of the axle...so most likely if it stopped moving, it was in the whole way
