OK took yall's advice and got a piston stop. Put it in and marked 0° TDC then turned it the other way and marked 0° TDC. Measured the distance between the marks and then went halfway between them. That should be exact TDC below is what I came out with (Second pen mark). Looks like the damper is off almost an Inch! I would have never thought it possible that it could spin. So that means when I put my distributor in it was at least a tooth off and when I was timing it I was actually retarding the timing causing the backfire and stall at 12 °! Got a new damper to install this weekend. As well as an Edelbrock carb rebuild kit, power steering pump and steering gear. A really big thanks everyone I will post and let you know if this took care of the timing issue. Got to LOVE the GBODYFORUM!!!!!
