Does anyone have a good suggestion as to what my engine's max RPM may be ABOUT with the following parts? I'm thinking 6K? Thanks guys!
Engine chevy 350 .060 10.1:1
eagle crank, rods, speed pro pistons, sealed power rings
clevite 77 bearings
comp cams cam 270h, 270 duration, 470 lift
comp cams lifters, hardened one piece push rods
pete jackson noisey gear drive
melling oil pump, oil drive
arp main studs, head bolts, rod bolts
Chevy double hump heads casting 3890462 ported, polished, 2.02I, 1.60E, hardened seats, screw in studs, guide plates
harland sharp roller rockers 1.5
summit stage 3 intake (edelbrock rpm air gap)
barry grant speed demon 650 electric choke, vacuum secondaries
hei dist, vacuum advance
clevite 77 bearings
