I am in the process of setting the ignition timing on my Ford truck. I replaced the distributor a month or so ago and just got around to setting the timing. I only drive it a mile or so but it seemed to run okay without the timing set.
So today I marked the correct timing mark (10° BTDC) with a silver sharpie and hooked the light up. I also disconnected the spout connector to disable the advance.
I was able to get the timing mark to line up, but everytime I tighten the distributor it it would turn and move a little. The distributor bolt is in an extremely awkward spot and hard to tighten without the wrench slipping off. I finally got the distributor tightened with the pointer on the sharpie line, but its not in the exact center of the line (sharpie line is maybe 1/8-3/16" thick).
This means it is maybe 1°, 2° degrees at the most off of exactly 10° BTDC. My question is, will this matter much if at all? I want to know if I can leave it at "good enough", or should I give it another go before I return the timing light to my friend?
Just FYI, the truck seemed to be pretty insensitive to the timing being changed. It wouldn't stall, even with the timing really advanced or retarded, and maybe my hearing is going, but I couldn't hear it ping when it was advanced really far.
