I picked up 200-4R out of an '89 Caprice with 80K miles. It was a genuine little old lady car with a stack of maintenance receipts that was in immaculate condition but hit hard in front. It will be going into my Cutlass behind a completely stock 305. After reading TONS of info by reputable builders, I compiled a list of recommended parts for a "street rod" level build. So here's the question...Is there anything else I should consider mandatory?
These guys are semi-local so I'll probably buy from them. The list so far:
-Hardened stator support
http://www.ebay.com/itm/200-4R-2004R-TR ... 27c5ac69a9
-Shift kit w/ .471 boost valve
http://www.ebay.com/itm/SUPERIOR-200-4R ... 27c59d092d
Hardened pump rings
http://www.ebay.com/itm/NEW-HARDENED-PU ... m1d81248ed
High stall convertor (2000-2600)
http://www.ebay.com/itm/700R4-200-4R-HI ... m1dd2926df
FWIW, the rearend is a limited slip 3.42. I know that the governor is pretty lame but so is my 305 so I probably won't mess with it yet. No need to shift at 5500 when I'm out of breath at 4000, right? What do you guys think? Any suggestions?
Hardened pump rings
