Inside vacuum connected to heater &ac box
55
Flordia
I need some help with my 83 Cutlass Calais I have changed out my engine to a 68 Rocket 350 an new trans tci .I need help connecting the vacuums back on my heater & AC box . if any one can find a diagram of it I would be greatful thank you. that way I can move my fuel line to other side of the frame an then get it hooked up to fuel pump an just keep moving on from there. Thanks yall
Used to one around here somewhere. There are usually 2 lines that go to the interior, on is the vacuum feed, from the engine, the other goes to the heater control valve. Sometimes there is also a canister. The color codes aren't always the same through the years of the g-bodies either. Can you tell us how many plastic vacuum lines are going through the passenger side grommet of the firewall?
