I’ve had an idea kicking around in my head for a while now concerning rear lower control arm mount bracing.
I’ve got a HRPartsNStuff kit lying around that I’ve yet to install, but a the thought of those Upper to Lower mount tie in braces that companies like UMI and BMR Suspension sell, why not pick up a set of those and add those in?
The ones BMR makes have a flat plate on the lower, which could allow for welding those into place- but I doubt that would be beneficial.
The idea here is to create another load path along the frame to help support the notched section. I’ve already got HR’s upper braces in place and there’s a set of IC brackets in there from Trick Chassis.
Then there’s one other addition I’d like to throw at this wall: “Sub”- Frame connectors.
Was picking through old threads via a google search one day and found motoheadmike’s GTO Wagon build, and he had an interesting substitute for boxing the frame in:
In theory, I could add another (!) tie in from the lower portion of these braces to the lower control arms, however I get there’d be an issue with the frame pulling on the lower mounts so much that I’d risk tearing them out.
Thoughts?
1980 Pontiac LeMans Station Wagon - G-T-faux (stuck with it, and can't shake it... like a bad case of herpes)
Well the S60 was ordered with 3.73s and LS1 housing ends (for LS1 brakes) in a stock width - we got an amazing deal. So the 8.5" and 7.625" are up for sale. In other news we are LS-ready! 10" x 2" oil pan notch is done with two 1" x 1" x 1/8" square tubes stacked; and the A/C compressor notch...
gbodyforum.com
Thoughts?
