Is this going to be better performance than a stock Olds 350 with an intake? What heads are you using? What is your expected compression ratio going to be? What kind of machine work did you have have done to the crank and block?
Why in the first post did you say that you put the cam in last night, and then honed the cylinders the next morning? Did you hone your cylinders with the cam in the engine?
