So i've started a new build if anyones interested in seeing what i'm up to now..
Project plans
-5.3 LS,turbo 400, atlas transfer case.
-1-ton 06 f350 super-duty axles full hydro steering
- 4 link front and rear with 16" coilovers and air bumps
-currie anti-rock sway bar kits
-46" baja claw tires on 20'' double bead locks (maybe some 42's for summer)
So at this point im still collecting parts.. here's what i have and where im at, The rear 4-link setup that was pre-existing should work fine...and a few more items and ill start mocking up the links/suspension and motor/trans placement.
Soo much room in the shop now
5.3 LS. all going well i'd like to do a trick flow top end kit, some flat tops and a fast or other similar port injection manifold style fuel system
Project plans
