I want to put solid tie rod adjusting sleeves on my Cutlass rather than the crappy rolled together piece of metal ones that come on it stock. I know that they exist in the aftermarket, but I wonder: Did GM (or anyone else) ever used them in an OEM application with the same threads as a G Body's tie rod ends? I would rather use a junkyard solution with better stock parts than part with real money for aftermarket pieces if I can, so does anyone know of a good junkyard source for these?
The idea behind the solid ones is that they do not flex as much and should hold their alignment better in turns as well as provide better steering response. They are common on newer cars with rack and pinion setups, but I have never seen a stock set on a pitman arm steering car like ours. I am hoping I am wrong and they do exist, maybe on a Jeep or something.
