Ive heard from some sources that a 307sbo intake will fit a 350 sbo. If so, then by using that intake with the computer carb and the ecm from the 307 will result in increased mpg, correct? I promise, no more dumb questions...lol.
bill said:Ive heard from some sources that a 307sbo intake will fit a 350 sbo. If so, then by using that intake with the computer carb and the ecm from the 307 will result in increased mpg, correct? I promise, no more dumb questions...lol.
dan2286 said:bill said:Ive heard from some sources that a 307sbo intake will fit a 350 sbo. If so, then by using that intake with the computer carb and the ecm from the 307 will result in increased mpg, correct? I promise, no more dumb questions...lol.
I believe it is the intake from 85 or 86 and earlier that will fit a 350. I believe the best one to use is the A4 intake. Using the computer may improve mpg, but it won't be much. People have done it, but you need to make sure you have a factory service manual with all the diagrams to make sure everything is hooked up correctly. You may need to play with the carb since the engine is bigger.
joe_padavano said:Many people have adapted the CCC system to 350, 403, and even 455 motors. Usually this was done to retain emissions inspection compliance (yes, technically the swap is illegal but it would be the rare inspection tech who could tell a 455 from a 307). The was a guy named Kevin Wong on the old Chubecto Olds Listserver who adapted the CCC system to a 455 and ended up burning a new PROM to optimize performance.
The biggest problem with the CCC system is that you can't alter the timing curve without burning a new PROM. One thing for certain is that the 307 timing curve will NOT be correct for a different engine. Also, you don't need the 307 intake to make the CCC system work on a different engine since the CCC Qjet bolts to any Olds Qjet intake. As noted, the A4 intake will bolt to any earlier SBO as a weight savings, but it has no performance benefit.
