So I put my Monte up on jack stands to an oil change, I drain all the oil out and then I get ready to pre fill the filters with oil( I have dual remote filters)
So I notice a difference internally between the two filters, one I can see almost to the bottom which I am used to and the other has something up high inside.
I call K & N and ask about it and was told they have different companies that manufacture them and was told one might be old stock, I replied they are from Summit do you really think they would have old stock? So I am still told they are the same.
So I go to fill the one in question and it takes less than a cap full of oil and basically spits it out and what is in won't go down
I contact them again and the tech guy says send them the pictures I have.
So in the meantime I have my buddy go the local Autozone to pick up the only one they had in stock, it ends up being the correct style so at least I can finish my oil change.
So I am still waiting to hear back at what K & N says but just replacing a filter I already bought a second time is not going to cut it.
These are the Ford style HP-3001 that I use. the first picture is a standard filter where you can see close to the bottom the last three are of the questionable filter.
UPDATE: They just informed me it is a "rolling design change" and it will open up and let oil in under pressure, I tried to explain that having to run two dry filters on the front of my car is not going to work for me, looks like I will be using a different brand filter next oil change.
