well i'v been off an on this board for awhile so heres my car
78 Monte Carlo Landau with factory power windows, locks, seats, moonroof, trunk release, cruise, even the factory trash can basically everything you could order back in the day.
Drivetrain wise i just dropped in a 496 BBC stroker dynoed at 625hp/610 tq all on 92 octane pump gas. Built up th-350 with 3500 stall convertor, 8.5" 3.42 geared posi rear end with adjustable upper arms and box lowers. Just replumbed by fuel system with a sumped stock tank with -10AN lines going to the mechanical fuel pump then -8AN to the carb.
Also redid the front suspenson with aftermarket adjustable upper control arms, tubular lower arms, modified g-body spindle with 13" corvette brakes and converted it from vacuum to hydroboost brakes.
up next for it is to build a custom subwoofer box, all new stereo, finish up the air conditioning. Yes a big block with air conditioning!!! then get her painted up.
