UPDATE JUNE 2012: I tried to sell the Caballero for several weeks and ended up trading it for a 2002 Honda VTX 1800. In 6 days I sold the VTX on Craigslist for $5,200. I drove a Honda Accord sedan for several months but there wasn't anything to wrench on with that car so I bought my current Gbody for $5,000 on Thanksgiving 2011. The build thread for that 1982 el Camino is linked here.
I'm going to use this post as a ledger to keep track of how much $$$ I sink into the Cab. It will also serve to keep tabs on my wish list and regular maintenance projects. If you've got any feedback on why I should use this or that part or if you know of a good source of the parts I'm looking for I'd appreciate the feedback.
LEDGER
1980 Caballero Laredo - craigslist.com/Tulsa - $3,850
Moog K6145T Lower Ball Joint x2 - rockauto.com - $49.98
Moog K6421 LCA Bushing Kit - rockauto.com - $40.79
Moog K6606 LCA Bumper x2 - rockauto.com - $10.80
Moog 5660 Front Coil Springs - rockauto.com - $56.75
Moog CC635 f-body Rear Coil Springs - rockauto.com - $52.79
Energy Suspension 9.5165R 1-1/4" sway bar bushings - jegs.com - $15.99
Energy Suspension 9.8110R Sway Bar End Links - jegs.com - $15.99
*Energy Suspension 3.4141G Body Mount Bushings - jegs.com - $134.99
BreakBest BH36847 Front Break Line x2 - O'reilly's - $19.96
Sylvania XtraVision Halogen H6054XV x2 - Walmart - $27.92
#13 Pool Ball Shifter - thehotrodgirl.com - $15.99
Pilot PLSW55BR LED Touch Switch - AutoZone - $9.95
Grant GRT-456 Club Sport Steering Wheel - Summit - $71.25
Grant GRT-3196 Installation Kit - Summit - $16.95
Edelbrock 1406 Barely used Carb. - ebay.com - $190.89
*Spectre Carb Adapter and Bolts - swap meet - $14
*2004 GrandAm rearview mirror - ebay.com - $21.20
Cardone 40-1681 Wiper Motor - AutoZone - $53.85
*Cardone 27-6550 quick ratio steering box - O'Reilly - $151.93
GMC Emblem x2 701.15707 - Schram Auto Parts - $24.89
ICON PM105 Blower Motor - O'Reilly - $16.99
Dashtechs El Camino Dash Pad - ebay.com - $34.94
Edelbrock Performer EPS 2701 - ebay.com - $88.21
Edelbrock SBC Cast Aluminum Valve Cover seconds - ebay.com - $52.19
Order from dixiemontecarlodepot.com - details below
*Replacement Rubber - Accelerator, Break & Clutch - $31.00
*LH & RH replacement window felts - $36.00
*Rear Roof Clips for Bed Molding - $12.00
*Bed Rail Molding Clips 2x - $50.00
dixiemontecarlodepot.com Shipping & Handling - $25.87
Coolant, Vaccum & Heater Hoses; Alt. Belt - Summit - $59.36
Summit SUM-G3090 - Fuel Line Feed - $15 .95
Summit SUM-800160 - 0 to 60 PSI fuel gauge - Summit - $17.95
Summit SUM-G1491 - 12 pt SBC intake bolt set - Summit - $10.69
General Motors NAL-10108470 - Thermostat Housing - Summit - $5.95
Summit SUM-G1414 - throttle return bracket - Summit - $8.95
Misc gaskets, plugs, grommets & hardware - Summit - $52.63
Summit SUM-G1339 - carb. return spring bracket - Summit - $6.95
Edelbrock EDL-1487 - Calibration Kit for 1406 carb. - Summit - $35.75
VDO Gauges VDO-150042 - Cockpit Vaccum Gauge - Summit - $29.95
Summit SUM-G2986 - Rich/Lean air-fuel gauge - Summit - $28.95
Summit SUM-G2989 - O2 sensor for A/F gauge - Summit - $27.95
Dual Gauge A-Pillar Pod - black - ebay.com - $69.50
Spectre SPE-4245 wire seperators - Summit - $5.95
AC Delco ACC-8123 - HEI Distributor Cap and Rotor - Summit - $19.95
Duplicolor DPL-DE1602 & DE1607 engine paint - O'reilly's - $17.95
HELP! 76945 GM Window Handle 2x - AutoZone - $13.98
Rockauto.com Wholesaler Closeout : details below
AC Delco Plug Wires - $23.79
*Kelsey Hayes Break PAds - $5.44
*Bendix drum break rebuild kit 2x - $13.82
Bosch Spark Plugs 8x - $6.56
Fel-Pro Oil Pan Gasket - $4.40
Kemparts Oil Pressure Switch w/ Gauge - $12.75
*Raybestos Rear Wheel Cylinder 2x - $5.38
*Standard Motor Coolant Temp. Sensor w/ Gauge - $10.81
Rockauto.com Shipping & Handling - $20.84
1986 Grand National Aluminum Drum Breaks - ebay.com - $117.28
*Jeep Grand Cherokee solid steering column shaft - ebay.com - $34
*New HEI distributor - ebay.com - $50
*Felpro 1256 - blue intake manifold gasket set - O'Reilly - $37
Everstart Maxx 75s - battery - Walmart - $77
* to be installed
Running Total: $6,025.50
PROJECT LIST
Engine Clean Up - Before & After <-- project link
WISHLIST
Rubber Bed Mat
Serpentine Belt Setup
Complete Weather Stripping Kit
ACC Carpet
Coy's C-55 17x8 w/ 235/50/R17 tires
LEDGER
* to be installed
PROJECT LIST
WISHLIST
Rubber Bed Mat
ACC Carpet
