Lift to fit 22s
2
I have a 1984 Cutlass Supreme, I want to sit this set of 22's so they wont rub in the front anymore. I currently have knuckles in the front but they still rub and I also have 1 1/2 inch spring lift cups that are not installed yet would that be enough so they wont rub anymore. also do I need new shocks or anything? Any advice would help. Thank you.
80ELCAMINOFLAKE
2,685
14
38
California So Cal
U really dont need a lift kit, if your running 245/30/22 tires then u should be koo, all you need to do it cut the inner finder like an inch on each side and it should clear just fine...Grab a dremal and cut away, u will know how much to cut, as you turn the wheel to see your clearence...should take u no more that 10 mins to do.. :wink:
My 78 malibu sits with no lift kit, no spacers, no nothing, all stock and looks and clear fine with that cut...hope this helps..
80ELCAMINOFLAKE
2,685
14
38
California So Cal
JamesIsTruth said:
What kind of Dermal did you use?
You can get one at your local auto parts for home depot...
but here a pic of the one i have....works wonders..i think everyone should have one..
LOWBARK
Aug 5, 2012
louisville ky.
yes you dont need to lift if you run a 245-30-22. ive been working in a custom wheel for about 7 yrs. in louisville ky and we do do it all day on gbodys.. run some air shocks and roll out.
