Im in the process of doing body mounts. The front 6 mounts came out fine but the rear 6 all had to be cut out from the top except 1 which was completely missing :x Anyway I got them all off so the body is just resting on the frame but I have a few questions...
1) I planned on using my engine hoist to lift the body at the trunk latch or the seat belt bolts. Which one is best or should I do 1 before the other?
2) How far can I lift the rear section of the body up without causing damage? The front clip is on and so are the doors. The rear will have to be higher for some welding.
3) Anything I need to disconnect to raise the body? I took the brake lines out of the clips on the frame so they can raise with the body.
4) Is it better to do one side at a time or lift the rear, then the middle, then the front?
Thanks for any input.
