Light issues
Swindells
Jun 22, 2019
69
64
35
I have been swapping all my bulbs in my cutlass over to LED
The front marker lights were working before I pulled the bulbs out to see what kind they were
After getting the LED bulbs I needed I replaced all around the outside of the car
Everything is working except the front markers
I swapped out the socket to a new socket because the old one was filthy being that it’s outside of the car and all corroded and green inside also
Threw a factory bulb in there and it’s barely getting enough juice to slightly go red inside
I thought fuse, but like I said, all the other lights are working and they are all on the same fuse
So I’m curious if anyone has encountered this issue
I was told maybe the wires themselves could be fried?
Please help
Anything would be appreciated
Classic bad ground. Check and clean all your ground points.
Maybe I’ll try to disconnect the ground itself and tap it to its own new point
See if that works
